WTB (any brand) Original Driving Plate Bushing Reamer
Smbayley
Topic author - Posts: 25
- First Name: Simon
- Last Name: Bayley
- * REQUIRED* Type and Year of Model Ts owned: 1925 Ford tourer
Hi all - looking to purchase a KRW Driving Plate Bushing Reamer.
I have attached a pic of what I am looking for. Any leads would be be appreciated.
Please email or DM if you can help.
Regards
Simon
Regards
Simon
Smbayley
- First Name: Simon
- Last Name: Bayley
Re: WTB KRW Driving Plate Bushing Reamer
More info to help in my quest: KR Wilson reamer marked W-8 sometimes on the square drive end flats. About 13" long; shank 1" Dia.; cutter end reams Driver Plate bushing to 1" I. D. in Model T transmission when bolted to brake drum to ensure positive alignment of all three bushings when rebuilding transmission.
Smbayley
- First Name: Simon
- Last Name: Bayley
Bump up the list - can anyone help out?
havnfun
- First Name: Joe
- Last Name: Kowalczyk
Just in case you’re open to a modern solution
https://drillsandcutters.com/h-hss-adju ... 16-1-1-16/
Regards,
- Last Name: Hatch
KRW were not only maker. Here is pictures of my Keystone reamer. Not for sale. But I have thought about having some made. Would not want to think about the cost!
RGould1910
- Last Name: Gould
Easy enuf to make. Buy a 15/16" chucking reamer on eBay and make a 1" sleeve to place over the 3/4" shank. Actually .999" per KRW . Best way to do it is make the sleeve a slip fit, then make it a permanent bond with sleeve retainer before turning the OD. Center by indexing off the reamer.
https://www.ebay.com/itm/351532060555?m ... media=COPY
RGould1910
- Last Name: Gould
Have parts on order to make one. Will post results if there is an interest
Smbayley
- First Name: Simon
- Last Name: Bayley
Please do and if you want to make two I would be interestedRGould1910 wrote: ↑Sun Mar 05, 2023 10:41 amHave parts on order to make one. Will post results if there is an interest
Smbayley
- First Name: Simon
- Last Name: Bayley
Open to any brand reamers that would do this job? Message me if you can help me out
