Auxiliary Transmissions - Light Muncie, Heavy Muncie, and Moore
namdc3
First Name: Nikolaus
Last Name: Martin
Post by namdc3 » Sun Mar 05, 2023 8:03 pm
Light Muncie - Gears look good with normal wear. Everything spins nice. Under-Direct-Over-Reverse. Roughly 1.78:1 U, 1:1 D, and 0.73:1 O. Were used in Ts and TTs. I don't have the couplers. $350
Heavy Case Muncie (painted one) - Gears look very, very good with exception of underdrive gear on lower shaft, which has 4-5 teeth in a row damaged. Photo of damage included. Everything spins nice. Under-Direct-Over-Reverse. Roughly 2:1 U, 1:1 D, and 0.73:1 O. Were used in Ts and TTs. I don't have the couplers. $300
Moore - I didn't open this one up, but everything shifts and spins nice. Under-Direct. 2:1 U and 1:1 D. Based on the torque tube adaptor diameters, I believe this to be a TT unit. Torque tubes and shafts included. $250
Pickup in Kansas City metro area or free delivery to Chickasha. Happy to answer any questions I can. Thanks!
namdc3
Last Name: Martin
Re: Auxiliary Transmissions - Light Muncie, Heavy Muncie, and Moore
Post by namdc3 » Sun Mar 05, 2023 8:08 pm
namdc3
Last Name: Martin
Post by namdc3 » Sun Mar 05, 2023 8:12 pm
namdc3
Last Name: Martin
Post by namdc3 » Sun Mar 05, 2023 8:13 pm
namdc3
Last Name: Martin
Post by namdc3 » Thu Mar 09, 2023 8:44 am
To the top
moddamatt
First Name: Matthew
Last Name: Lewis
Post by moddamatt » Sat Mar 18, 2023 5:21 pm
Hello, I actually bought the Moore transmission from y'all's table yesterday and I figured I'd give an update. I opened it pretty easily and every part seems in perfect condition. Now If only I could find part diagrams for it, gonna be fun getting the proper bearings.
namdc3
Last Name: Martin
Post by namdc3 » Sat Mar 18, 2023 9:45 pm
Awesome! I’m glad to hear that! It sure shifted nice, and I’m glad the gears look good! The Muncies haven’t sold, so if anyone is through Kansas City sometime and wants one or two, let me know.
First Name: craig
Last Name: leach
Post by Craig Leach » Sat Mar 18, 2023 10:05 pm
Hi Mathew,
Check the dimensions of the bearings you may find that there are modern bearings that match the dimensions. I found that some Warfords
use the same bearings as model A's and can be had in fully sealed versions that will work great for a good price. Ed Archer turned me on to
this for Muncies and found it applies to many other applications. If you leave the seals in they don't leak very much and the bearings will
last longer than we will right out of the box. Thanks Ed. If you read Lane machines info they do the same.
namdc3
Last Name: Martin
Post by namdc3 » Fri Apr 28, 2023 8:42 am
Both Muncies available. Updated prices in first post.
Tom Dove Jr
Last Name: Dove
* REQUIRED* Type and Year of Model Ts owned: 1925 Touring, 1925 parts car(?)
Board Member Since: 2022
Post by Tom Dove Jr » Thu May 18, 2023 1:31 pm
Interested in the Light Muncie if still available. Delivery would be to 95823.
Thanks!
Tom
I have never let my schooling interfere with my education.
Education consists mainly of what we have unlearned.
Tom Dove Jr
Last Name: Dove
Post by Tom Dove Jr » Tue May 23, 2023 11:44 am
:::bump:::
WorldChamp1914
First Name: Gary
Last Name: Hagen
Post by WorldChamp1914 » Tue May 23, 2023 12:23 pm
Any Muncie support brackets?
namdc3
Last Name: Martin
Post by namdc3 » Tue May 23, 2023 12:43 pm
Hey, Tom. I'm sorry that I didn't see your original post. I didn't get a notification. I'd prefer not to ship it, so I'll likely drag it to Chickasha again next year.
Gary, no, I don't have the support of the couplers. Sorry.
First Name: craig
Last Name: leach
Post by Craig Leach » Tue May 23, 2023 1:12 pm
Gary,
Support/crossmembers and couplings are hard to find for Muncies. I have been making my own out of self preservation. I made a crossmember
out of running board support & the drive couplings out of 13/16" deep Budd wheel inner nut socket a 7/8" piece of square stock
(milled to 13/16") and the rear coupling out of a cut down spicer PTO drive line yoke. Just want to say that you might not want to pass up a
good Muncie becuse it dosn't have them.
cross member.jpg (23.75 KiB) Viewed 2120 times
Muncie drive.jpg (21.91 KiB) Viewed 2120 times
Tom Dove Jr
Last Name: Dove
Post by Tom Dove Jr » Tue May 23, 2023 4:17 pm
Nikolas,
Really sorry to hear that. If it would help, I can prepay everything. Unfortunately I’m a few years away from traveling that direction.
Thanks!
Tom
