SOLD- FS Ruckstell Large Drum Rebuilt Rear Axle Assembly
MAG
Last Name: Gember
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring 1926 Runabout 1926 Coupe
Post by MAG » Wed Mar 08, 2023 7:49 pm
o Fully rebuilt Ruckstell large drum rear axle assembly including a Ruckstell center shifter & control rod, relined emergency brake shoes with rods & and supports – painted gloss black – full assembly ready to install.
o The total rebuild included all NEW: standard ring & pinion, axle shafts, hardened bearing sleeves, inner and outer modern seals, bushings, shims, thrust washer, drive shaft & bushing, modern pinion bearing, shift lock assembly, emergency brake cams & bushings, emergency brake shoes with hand brake rods & and supports.
o Full disassembly, cleaned, inspected, repaired as needed, then professionally reassembled with high quality parts. Then a quality high gloss black paint was applied. This is a full high quality Ruckstell rear axle assembly!
o Complete build sheet of parts & cost upon request. Must pick up. Can be delivered to Chickasha. $3850 - Changed price due to typo. Email me at markpaulagember AT aol dot com[
SOLD
LD Ruckstell 2s.jpg (61.65 KiB) Viewed 1161 times
LD Ruckstell 3s.jpg (62.94 KiB) Viewed 1161 times
LD Ruckstell 4s.jpg (47.69 KiB) Viewed 1161 times
LD Ruckstell 5s.jpg (60.67 KiB) Viewed 1161 times
LD Ruckstell 6s.jpg (48.87 KiB) Viewed 1161 times
MAG
Last Name: Gember
Re: FS Ruckstell Large Drum Rebuilt Rear Axle Assembly CHANGED PRICE
Post by MAG » Thu Mar 09, 2023 10:28 am
Updated price to $3850 due to typo in original add.
