FS Lots of parts. 15% OFF any parts on my list
BenLefebre
Topic author - Posts: 83
- First Name: Reuben
- Last Name: Lefebre
- * REQUIRED* Type and Year of Model Ts owned: All T's sold now. Selling my parts
FOR SALE - I have quite a few more items available at 15% OFF my latest list that was sent out to many of you that requested it. If any one else would like one, just email me - benlefebre@juno.com -and I'll attach it. Check out my ad from Saturday 02-23-19 ,at 8:52PM for lots of other items . If you would like photos of any of the items, I can also attach them, if you send the item #'s . #49 -AC speedometer pinion gear -as close to new as you'll find. For 21"tires,has 21 teeth. #58- Stewart speedometer dash mount bkt. for T. 1919-1925 and also 26-27 if using the #160 speedometer head. Instruction how to mount are in the MTFCA speedo book.#54-pair Stewart speedometer inner cable chain link ends .#63-Stewart road wheel gear #30333 - 58T/8P for late 25& 1926-27 with 21' tires & wood wheels ,and using the #1913 drive-excellent. There are many speedo head bezels listed for 3" Stewart heads, some painted black, also some brass. Some bkts. #64- Very nice Stewart Warner Speedometer corp. Early T brass/Black speedo head w/ brass bezel, 60MPH unit. Shows MPH , Season mileage ,& Trip .On the face says E56712-13 (which would be for 1913.There is a fine hair line crack on the lower end of the bezel. #59- A good used #2301 Stewart script pinion gear, which is correct for many model years of T's, as well as many vintage cars that used the #1913 and #1959 speedo drives. #74 -Rear knock Off wheel puller for T's. screws onto axle threads & tap with a hammer. The tool is solid & heavy (2Lbs ).# Model T Magnito horn bell w/flange Very good condition. Painted black. 7 1/4" long . Bell is 3 1/2" across. #83A & 83B are like the original T2335 tool kit tool.(nice ones).#-79A & 80A Are both original tool kit tools -adjustable wrenches T1387 Ford script(adjust smoothly. Thanks for looking. Ben
T-Dreamer
- First Name: Doug
- Last Name: Olsen
- * REQUIRED* Type and Year of Model Ts owned: 1920 Touring
Re: FS Lots of parts. 15% OFF any parts on my list
Sent you a PM.
-Doug
-Doug
Check the date on the ad.
