Hello, i found this parts.
Where do you buy ?
S-176 - 22-25 TOURING AND ROADSTER FRONT FLOOR BOARD SUPPORTS (PR)
Thanks for the help
Topic author - Posts: 10
- First Name: Stephane
- Last Name: Lezzier
- * REQUIRED* Type and Year of Model Ts owned: Touring US 1918
- Board Member Since: 2022
- Attachments
- s-176.jpg (13.32 KiB) Viewed 1151 times
- First Name: DAN
- Last Name: MCEACHERN
Re: FRONT FLOOR BOARD SUPPORTS
Stephane- If you are looking to buy, I think I have an original set.
There are a few tears that will need repair but overall very useable.
here are a few pictures. My e-mail is dmcgearsATyahooDOTcom.
But it is not a same to ask for my 1922 Touring
- First Name: Shannon
- Last Name: Helm
Have you checked with Howell's Sheet Metal directly? Best to call them but they are sometimes hard to get ahold of if they are out in the shop-- just keep trying.
https://fordor.com/category.cfm?cat=192 ... 0927modelt
You might also check with Chaffin's (chaffinsgarage.com) or Lang's (modeltford.com); both are great to deal with.
And, put up a wanted ad here if you would like to find a pair of originals and someone may have a set for you. Good luck!
Dan
I suspect that your parts might be from an enclosed car (?)
this is what Stephane needs: It does look like Howell's is the source of them as new
- First Name: DAN
HI Scott- you might be correct regarding the correct supports. Perhaps someone else will need the ones I have for their project.
Mine obviously have provision for the three body mount bracket bolts to pass thru the supports I have.
