Wanted Chicago trans case
t-time
Last Name: Bruto
* REQUIRED* Type and Year of Model Ts owned: 1914 speedster 1927 coupe
Post by t-time » Wed May 24, 2023 11:21 am
Going through a Chicago transmission and discovered the case has been welded. I would rather not use it so I'm looking for another.
Michael Peternell
First Name: Michael
Last Name: Peternell
Re: Wanted Chicago trans case
Post by Michael Peternell » Wed May 24, 2023 1:20 pm
There are two different Chicago cases. One says patent pending the other does not. Different bearings between the two. I've got one you can have for the cost of postage. Might get a little spendy MN to CA. You can let me know if you can't find one closer.
Mike Peternell
t-time
Last Name: Bruto
Post by t-time » Wed May 24, 2023 5:27 pm
This one has patent pending in the casting. Thank you
t-time
Last Name: Bruto
Post by t-time » Mon Jun 05, 2023 2:27 pm
A case has been located. thanks to everyone who responded.
TeveS-Nor Cal
Last Name: Straw
Post by TeveS-Nor Cal » Mon Jun 05, 2023 7:08 pm
Have you opened it?
t-time
Last Name: Bruto
Post by t-time » Tue Jun 06, 2023 9:21 am
I have, I've seen worse. I'll start with evaporust and see what it will do. Thanks again.
