ACCESSORY STEERIN GEAR
Liberty Garage
First Name: Steven
Last Name: Nelson
* REQUIRED* Type and Year of Model Ts owned: 2 speedsters, 24 touring,19 pickup
Post by Liberty Garage » Fri Jun 16, 2023 10:11 pm
Model T accessory steering gear. Mounts in the same position as the original steering mount. $400 + ship
WorldChamp1914
First Name: Gary
Last Name: Hagen
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring and a 1921 Sightseeing Bus.See SF On a Dime
Re: ACCESSORY STEERIN GEAR
Post by WorldChamp1914 » Sat Jun 17, 2023 2:08 am
What is it exactly?…..original type?
Liberty Garage
First Name: Steven
Last Name: Nelson
Post by Liberty Garage » Sun Jun 18, 2023 12:51 pm
No name on it. Planetary gears in the housing
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Sat Jun 24, 2023 4:01 pm
If anyone does know, I have the same one. It is light weight, was thinking it is off a cycle car, or something around that size.
First Name: craig
Last Name: leach
Post by Craig Leach » Sat Jun 24, 2023 8:22 pm
To the best of my knowlege that is a accessory steering system for model T. I believe it was designed to have a better ratio to make steering
easier & prevent steering whip in revearse. There should be a coupling to the T shaft & a device to eliminate the gears in the column. A online
search may shed more light on the part. I have seen them sell for about that amount before. So in todays market that should be a good price.
Post by DanTreace » Thu Jun 29, 2023 2:35 pm
Might be somewhat like this T accessory steering gear?, seems very similar. But didn’t see the T spark and throttle rod guides in that casting like this one has.
Image 6-28-22 at 10.43 AM.jpeg (33.25 KiB) Viewed 1075 times
