FS - left side mount belt drive alternator
t-time
Last Name: Bruto
* REQUIRED* Type and Year of Model Ts owned: 1914 speedster 1927 coupe
Post by t-time » Mon Jun 26, 2023 6:31 pm
New 12 volt alternator kit for 09-27 for model T. Simple bolt on installation, no modifications to engine required. Mounts on the left water outlet neck bolt using a special included bolt, tension bracket uses two of the block to pan bolts. 12 volt, 30 amp, negative ground mini Denso style alternator has a flat belt pulley. Requires a longer belt (not included). 2 wire hook up - positive to ammeter, ignition on switched positive.
Nikko012
First Name: Raymond
Last Name: Emling
* REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo, 1914 roadster, building:1910 roadster, 1911 touring
Re: FS - left side mount belt drive alternator
Post by Nikko012 » Wed Jun 28, 2023 2:16 pm
Is this your design. I am interested.thanks ray
t-time
Last Name: Bruto
Post by t-time » Wed Jun 28, 2023 3:25 pm
It is, I needed something on my speedster so I came up with this.
Post by RajoRacer » Wed Jun 28, 2023 7:06 pm
Nice design - was also wondering the same !
DOBSONN
First Name: Neil
Last Name: Dobson
* REQUIRED* Type and Year of Model Ts owned: 5
Post by DOBSONN » Tue Jul 04, 2023 5:50 pm
Hi Mark, I would be keen to purchase one - are you able to ship internationally to New Zealand.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Wed Jul 05, 2023 9:06 am
Hi Mark, Interested to get one for my speedster either. I have USA address as well. mario dot brossard at sympatico dot ca
Super Mario Bross ;)
1911 Touring
1914 Speedster
t-time
Last Name: Bruto
Post by t-time » Thu Jul 13, 2023 1:04 pm
back to the top
Wayne Mims
First Name: Ervin
Last Name: Mims
* REQUIRED* Type and Year of Model Ts owned: 12 rdstr 13 tor 14 tor 15 pickup 22 drs coupe 21 center door
Post by Wayne Mims » Fri Jul 14, 2023 2:15 pm
I too, would be interested in one or two of them email address EWM 1948@yahoo.com or phone 512-995-6013 Wayne Mims
Sarikatime
Last Name: Seress
Post by Sarikatime » Sat Jul 15, 2023 12:07 pm
Birdhaven sells the complete setup, no brainer installation. Just thinking out loud.
t-time
Last Name: Bruto
Post by t-time » Sat Jul 15, 2023 2:05 pm
This is also a no brainer install and does not use head bolts for mounting, plus the alternator is smaller than the delco unit. The only part not in the kit is a longer belt. Just explaining out loud.
Randall strickland
First Name: Randall
Last Name: Strickland
Post by Randall strickland » Mon Jul 17, 2023 6:53 pm
Heres the same I came up with 7-8 years ago!
t-time
Last Name: Bruto
Post by t-time » Tue Jul 18, 2023 12:50 pm
Great minds think alike!
6 volt version in the works.
t-time
Last Name: Bruto
Post by t-time » Mon Jul 31, 2023 9:40 am
back to the top
t-time
Last Name: Bruto
Post by t-time » Sat Nov 18, 2023 5:57 pm
6 volt version now available. https://www.ebay.com/itm/266502857774
WillsT
First Name: Will
Last Name: Snyders
* REQUIRED* Type and Year of Model Ts owned: 1915 Roadster Pickup
Post by WillsT » Sun Nov 19, 2023 6:26 pm
Ordered 12 volt version from EBay, very good price
Excellent product and mounting hardware, simple to install
It is a 2 wire compact alternator, one wire for battery positive, one for switch on position
For my 1915 needed a 34” belt.
