For Sale- rear block spacer used when installing a Model A crankshaft with an unshortened rear main bearing. This spacer is used when
moving the block forward on the crankcase, allowing the transmission cover to seal on the spacer. Moving the block ahead makes in unnecessary to shorten the rear main journal.
Machined from aluminum plate- not a casting. $90.00 plus $12.00 USPS Priority Mail shipping. dmcgearsATyahooDOTcom.
FS-Rear Block Spacer for A Crank Conversion in a T block
Dan McEachern
Topic author - Posts: 1484
- First Name: DAN
- Last Name: MCEACHERN
