FS KMC MANIFOLD
Mark Chaffin
Last Name: Chaffin
FS KMC MANIFOLD
Post by Mark Chaffin » Tue Aug 08, 2023 1:32 pm
Neat accessory intake / exhaust manifold. Yours for $50 plus domestic shipping. Mark Chaffin (951) 805-0928
DustySpokes
First Name: Edmund
Last Name: Niedzielski
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
Re: FS KMC MANIFOLD
Post by DustySpokes » Tue Aug 08, 2023 2:27 pm
OK - I gotta ask this question, what else is needed to make this setup fully complete ? Me thinks there is a special little Kerosene tank as this setup is meant to be able to run kerosene as well as gasoline. ( I am pretty sure that I have a New Old Stock KMC brass carb , but not sure if it is the same model ) . -Dusty
Mark Chaffin
Last Name: Chaffin
Re: FS KMC MANIFOLD
Post by Mark Chaffin » Tue Aug 08, 2023 3:39 pm
I believe the tank is all. Everything else is there.
Tourabout
First Name: Robbie
Last Name: Price
Re: FS KMC MANIFOLD
Post by Tourabout » Tue Aug 08, 2023 5:05 pm
I had one in the original wooden crate. It had a small gas tank to get the Model T started before switching it over to kerosene. It also had a 1/8” steel spacer shaped like a head gasket that you placed between two head gaskets to lessen the compression in order to run on kerosene.
Mark Chaffin
Last Name: Chaffin
Re: FS KMC MANIFOLD
Post by Mark Chaffin » Tue Aug 08, 2023 5:34 pm
Thanks for the additional info. Personally, I would probably remove the carburetor and add a regular updraft carburetor.
DustySpokes
First Name: Edmund
Re: FS KMC MANIFOLD
Post by DustySpokes » Tue Aug 29, 2023 1:44 pm
I have a New Old Stock, never used KMC carb that I would sell to someone who would want to have a very interesting accessory. I can let it go for $130
This is likely THE most elusive carbs you would ever find. With the purchase of Mark's setup , you would be in great shape with spare parts. -Dusty
Re: FS KMC MANIFOLD
Post by TXGOAT2 » Tue Aug 29, 2023 2:51 pm
If only kerosene was still 6 cents a gallon...
Last Name: Hatch
Re: FS KMC MANIFOLD
Post by Dan Hatch » Tue Aug 29, 2023 3:04 pm
If only kerosene was still kerosene!
Re: FS KMC MANIFOLD
Post by TXGOAT2 » Tue Aug 29, 2023 9:29 pm
It's denatured, like so much else.
Mark Chaffin
Last Name: Chaffin
Re: FS KMC MANIFOLD
Post by Mark Chaffin » Tue Aug 29, 2023 9:41 pm
My first wife had me denatured after our two girls were born. 😀
