I have a Stewart model 26 on my 1912 van. This is my reserve one. I figure since I have never fitted the internal cable on my van since I built it in 1995, its not ever likely to wear out, so someone might put this one to use.
It has a scratch on the glass at 5 mph. Apart from that it is undamaged. It has had very little use, as there is no wear at the cable coupling. I tested it on my battery drill, and it runs up evenly and holds a steady needle.
Complete with original adjustable angle bracket, with most of the brass plating still on the clamp bolts and mounting rod. $650 includes postage to your door.
FS Stewart model 26 speedo
Topic author - Posts: 6879
Re: FS Stewart model 26 speedo
New lower price. $500
