Found! Wanted starter motor cover plates
Topic author - Posts: 1445
- First Name: Keith
- Last Name: Townsend
I'm looking for the block off covers where a starter motor goes on a late hogshead.
Thanks,
Keith
Thanks,
Keith
Re: Wanted starter motor cover plates
Pretty sure I can fix you up Keith !
If you can't find one locally, I can help.
- First Name: Mike
- Last Name: Leonard
- * REQUIRED* Type and Year of Model Ts owned: 6
If all else fails, I have them. ctleonard64@gmail.com
I believe I have several sets - drop me a note.
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
- Board Member Since: 2013
Keith:
I also have the two items that you need, call me if everything else does not work out. Tom Elliott
- First Name: Keith
Parts found. Thanks, guys!
