I am wanting to do away with the aluminum water pump on my T due to it constantly reacting with the iron block and causing that fun chemical reaction that ruins everything. Are there any good iron ones out there that would be a good replacement that one would consider selling me? And yes..... I know everyone thinks I should do it the way Henry intended. I would still like water pump.
Thanks,
Bryce
WTB Iron water pump
- First Name: craig
- Last Name: leach
Re: WTB Iron water pump
Hi Bryce,
I understand the aluminum issue well, just worked on a friends touring ( he had to have the radiator cleaned out for that reason) I just went
through a drawer of water pumps to make a list of parts I will need to rebuild them. I replace the shafts with 304 SS & re-bush & replace the
packing with new. I have several styles if you have a preference? I'm leaving for the Texas T Party Tour in the morning and will be gone for a
while ( it's along drive ) If you get a chance give me a call six 0 two-7 six 9-0 two five 7
Tim D
- Last Name: Dickson
- * REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
I have some cast iron pumps listed one here for sale they will need to be gone thru. but they still spin
Tim D
Back to the top
Jimmie
- First Name: Jimmie
- Last Name: Rodgers
- * REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1919 Roadster
I have couple of different water pumps. Both spin
One has a broken mount casting - I have the piece - it could be brazed.
I live in Michigan.
I live in Michigan.
