WTB - Hot Air Pipe
JR Ewing
First Name: Joshua
Last Name: Ewing
* REQUIRED* Type and Year of Model Ts owned: 1918 Ford Model T Roadster, 1936 Ford Pickup (I know, not a T)
WTB - Hot Air Pipe
Post by JR Ewing » Sat Dec 09, 2023 9:43 am
I’m looking for an original hot air pipe for my 1918 Roadster. I know there are a few different versions of this part over the years, so whichever one will fit my 1918 Roadster.
Thanks for the help!
Re: WTB - Hot Air Pipe
Post by TRDxB2 » Sat Dec 09, 2023 11:01 am
This is from the 1918 Parts Manual. Dan Mari had some made. If he doesn't have any left I have one I ordered to help the build quantity & for whomever needed one at a later date when they were gone.
This is an alternative. Was an aftermarket accessory. The base design had an adjustable air intake - they also has an end to cause cirular air flow. Some owners removed this & that from them. I have a couple modified for sale ($10+shipping)
JR Ewing
First Name: Joshua
Last Name: Ewing
Post by JR Ewing » Sat Dec 09, 2023 11:34 am
Thanks Frank,
I would like to find the earlier version for my car. If I can't, would one of the later versions work?
Post by TRDxB2 » Sat Dec 09, 2023 2:52 pm
Thanks Frank,
It appears so based on the parts list (1912-25).
There are similar styles as well. Based on the part that wraps the manifold I'd say its what dated as 19-23 . The difference too were because of the manifold clamps and carburetor rods
Looks like Lang's may have one
early pipe.png (59.23 KiB) Viewed 1339 times
JR Ewing
First Name: Joshua
Last Name: Ewing
Post by JR Ewing » Sat Dec 09, 2023 5:08 pm
Thanks. I’ve heard the repops are pretty cheap. I’ll see if I can find a good original, either the ‘18 and earlier version or the ‘19-‘23. Thanks for your help.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Sun Dec 10, 2023 12:27 pm
Joshua:
I have correct carb pipes available for your '18. I'll send you a private message.
JR Ewing
First Name: Joshua
Last Name: Ewing
Post by JR Ewing » Sun Dec 10, 2023 5:11 pm
Thanks Erik!
