original APCO 437 Spring Perch Removal Tool
Unprr
Topic author - Posts: 294
- Last Name: Schmidt
- * REQUIRED* Type and Year of Model Ts owned: 1927 coupe, 1924 Model T pickup
Here is an original APCO 437 Spring Perch Removal Tool. This original Model T front axle perch remover utilizes 2 claws/clamps that go around the front axle, and the nipple threaded driver pushes on the dimpled threaded portion of the perch and drives it out. This tool was designed for routine maintenance needs of perches in good condition. Perfect tool for that well maintained T, simply use to remove your perches to rebush or replace. Nice tool in good condition.
No breakers, welds are known defects.
Asking $200 includes shipping, lower 48 states.
Sorry, no international shipping.
- Attachments
- IMG_2023-12-14-134053.jpeg (21.82 KiB) Viewed 3371 times
- IMG_2023-12-14-134142.jpeg (30.51 KiB) Viewed 3371 times
- IMG_2023-12-14-134238.jpeg (30.86 KiB) Viewed 3371 times
- IMG_2023-12-14-133628.jpeg (21.96 KiB) Viewed 3371 times
Charlie_26_TT_Ccab
- First Name: Charlie
- Last Name: Coleman
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT C Cab Stakebed Truck
Re: original APCO 437 Spring Perch Removal Tool
Sent you an email.
Unprr
To the top of post
Unprr
Price reduced to $185, with shipping.
Unprr
I received this post from a Model T friend. His reply was confirmed by another member. It appears I made a mistake on my description.
Sorry, I will take down this post and hang this tool on my wall of mistakes.
George Schmidt
Hi George, the perch tool you have for sale looks like a modified steering
wheel puller. I can sent you photo of an unmodified tool if requested.
Regards, Walt
George Schmidt
Regards, Walt
Unprr
This item is no longer for sale.
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
FYI- Here is a pic of an unmodified apco steering wheel puller. The one you advertised looks like the arms were modified or notched for an unknown reason by a previous owner.
namdc3
- First Name: Nikolaus
- Last Name: Martin
Ed, could you post a photo of your puller on a steering wheel? I have one that doesn’t seem to grip a wheel very well (cast or pressed steel). It certainly doesn’t fit like the one in this 1923 ad. Note that the one in the ad has straight drops, and mine and the one you pictured have a bend.
RVA23T
- Last Name: C
He was selling the SPRING perch remover not a steering wheel removerThreePedalTapDancer wrote: ↑Sun Dec 17, 2023 10:23 pmFYI- Here is a pic of an unmodified apco steering wheel puller. The one you advertised looks like the arms were modified or notched for an unknown reason by a previous owner.
Unprr
RVA23T, thanks for the confirmation of my part, being a spring perch remover.
As the photo shows, it has the correct APCO number
George
George
namdc3
- Last Name: Martin
I believe 437 to be the part number for the yoke, which is shared on at least two tools - the No. 8 perch pusher and No. 2 steering wheel puller.
Unprr
We agree to disagree.
It still looks good, on my wall of mistakes. LOL
namdc3
- Last Name: Martin
I don’t recall disagreeing. I agree that your puller is a perch pusher - either a factory variant of the more common styles or a modified steering wheel puller. I actually lean more toward factory variant. 437 is definitely not the tool number though. It is on steering wheel, perch, and I believe hub pullers, too. The catalog page I posted above shows the tool numbers, which are the same numbers used in other ads from the mid-teens and twenties.
namdc3
- Last Name: Martin
If you could confirm that this old Etsy listing is not the same puller as yours, I think you’d prove half your point. It has the same jaw notches. The yoke appears to have the same casting glob patterns, though, so I was unsure if it was indeed a second puller of that style or the same one.
https://www.etsy.com/listing/1103610776 ... ng_details
It does appear that the 437 is the number of the yoke and not the fuction of the puller
https://www.worthpoint.com/worthopedia/ ... 1787315606 --
I also came across a picture/ad for the APCO wheel puller & it was noted as 437 and thought to be a perch puller. Lost the image
If you look at the length of the hooks the "Perch Pusher" ones are longer --
This is another could not be a "Perch Pusher" because the hooks could not wrap over the axle, their ends interfere
