For Sale: Miscellaneous Model T Parts. Shipping not included.
Clockwise: 1917-1920 Coil Box Sheet Metal, needs straightening, $8; 23-25 Coupe? Front Body mounts, some pitting but still quite solid, $20 pair; 26-27 Fordor Steering Bracket T932C, $20; Raw casting in brass for reproduction early firewall bracket, $10; Heat stoves, fair condition, $5 each; More Coil Box sheet metal for 20-25, the springs in the clips are weak, $8.
Left to right: Rear Crossmember, 14-25, looks good $25; Front Crossmember, some of the rivet holes are a little bit wallowed, $20, 26-27 Fan w/ outlet, the fan has some fatigue cracks, $15; 26-27 Spare Tire Carrier missing one arm $20.
Clockwise: Non-T Klaxon Motor, good quality, needs restoration $20; brass elbow for 1 1/2" to 1 5/8 right angle, $5; Accessory switches $5 each; Non-T accessory bullet blinkers for hot rods, missing lenses, $5 pair.
Left To Right: Misc Transmission Pedals, Smooth, $2 each, cams $1 each; 26-27 clutch pedal $5; transmission cover, $5; valve cover with hole cut in it $1.
Left to Right: What I believe is a 26-27 window regulator, spring is broke, gear is loose, $10; misc brackets $1 each.
Thanks for Looking!
Misc. Model T Parts $25 and Under
Topic author - Posts: 481
- First Name: Rodger
- Last Name: Erickson
- * REQUIRED* Type and Year of Model Ts owned: 1920 Speedster
Re: Misc. Model T Parts $25 and Under
Adding some more stuff, shipping is not included:
Set of non-detachable bands, $8
A brass "Twist" from a right hand "Double Twist" horn that someone was trying to convert to left hand, and didn't get very far, $5.
- First Name: Robert
- Last Name: Parke
I'll take the 26-27 water pump and fan and most of the brackets in picture 5. I'll send a pm with more details.
- First Name: William
- Last Name: Rathert
- * REQUIRED* Type and Year of Model Ts owned: 4
Would like to buy the elbow. Thanks
The horn twist, 26 fan, elbow, and rear x-member are spoken for.
Thanks MTFCA
Thanks MTFCA
Would like both of these of these. Can PayPal or check Shipping to 61265 (try USPS Ground Advantage maybe best)
