Spiral wound rear axle roller bearings SOLD
Topic author - Posts: 1713
- First Name: Layden
- Last Name: Butler
Rear axle roller bearings for Model T cars part # 2508, these are for both inner and outer and left and right side, lightly used very good condition and measure .002" wear or less on the rollers, no loose cages, limited number available, most have no makers markings but some say Hyatt and a few Ford, all are the original style spiral wound rollers and probably date from the 1920s, they have been cleaned in solvent but you should clean again to get any residual out of the inside of the rollers.
Last edited by Layden Butler on Fri Jul 12, 2024 12:38 pm, edited 1 time in total.
- Last Name: Butler
Re: Spiral wound rear axle roller bearings F/S
Still have a few available. When they are gone there will be no more! Not being reproduced and probably never will be.
No disappointed buyers!
