Wanted: Early 1920 parts
Philip Lawrence
First Name: Philip
Last Name: Lawrence
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Runabout, 1919 Touring
Board Member Since: 2014
Post by Philip Lawrence » Wed Mar 06, 2024 12:45 am
I'm looking for an early starter switch and frame mounted bracket that was riveted to the frame. These were separate parts. They are shown on page 279 (lower corner) of Bruce McCalley's book. I'm also looking for a magneto horn as shown on the same page.
Lastly I need a spare tire carrier for the rear of the car. I'm looking for one in very good condition. Thanks in advance.
Last edited by Philip Lawrence on Thu Apr 04, 2024 11:13 pm, edited 1 time in total.
Re: Wanted: Early 1920 parts
Post by Allan » Wed Mar 06, 2024 6:17 am
I can help with the switch and panel, minus the ammeter. The switch and panel are in very good order. If you have a need for the starter switch it would indicate that your car has a starter and generator. If this is the case, then the correct horn is a battery horn. The magneto horn was used on non starter cars.
Hope this helps.
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Post by Karl Von Neumann » Wed Mar 06, 2024 2:19 pm
Phil I may have the starter button and the carrier
Jim, Sr.
First Name: Jim, Sr.
Last Name: Rodell
* REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
Post by Jim, Sr. » Wed Mar 06, 2024 11:57 pm
Hope this helps.
Allan, It seems logical that a car with the starter and generator would have a battery horn, Ford did not use battery horns until March of 1922,according to John Regan (PIEWAGON). John did the research, and he was the maker of the reproduction horns when he was the owner of FUNPROJECTS Magneto horns were used before that and were still used on the Model T's and Model TT trucks that did not have the starter and generator system, until the end of Model T production.The first battery horns that Ford used,were supplied by Ames, until Ford could produce them.
1922 Coupe , 1926 Touring
Philip Lawrence
First Name: Philip
Last Name: Lawrence
Post by Philip Lawrence » Tue Mar 26, 2024 11:59 pm
Still looking for the frame mounted starter switch bracket, associated switch and Ames magneto horn. I now have the dash mounted ignition/light switch assembly (thanks Allan).
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Wed Mar 27, 2024 9:37 am
I think the regular Canadian/Australian cast ignition switch handle & panel may be slightly different than the “early” ‘19/‘20 cast switch handle & panel. If you are restoring a car for judging, you may want to research that. I have a couple early switches and more than just the handle is different than later production.
Post by Jerry VanOoteghem » Wed Mar 27, 2024 10:58 am
Can you please post a picture of what you need? I'm not going to dig through my stuff to find McCalley's book. :)
Philip Lawrence
First Name: Philip
Last Name: Lawrence
Post by Philip Lawrence » Wed Mar 27, 2024 11:47 am
Jerry, here's a photo of what I'm looking for.
Post by Allan » Thu Mar 28, 2024 1:49 am
Thank you Jim. At least I got the bit about the non starter cars and trucks still having a magneto horn. Now I have to go looking for a magneto horn for the 1920 buckboard i restored in 1987! I wondered why the 1922 wooden firewalls stiil had the relief and holes for the magneto horn mounting.
Philip Lawrence
First Name: Philip
Last Name: Lawrence
Post by Philip Lawrence » Sat Apr 13, 2024 11:43 pm
I'm still looking for the starter switch and mounting bracket.
