Made to mount on a vertical wooden dash as on a brass era Model T, takes off and runs when wound but should go off to the shop for cleaning and lube.
Nickel plated brass, rim wind and rim set. Will need a mounting bracket made for it, the bracket is hidden by the clock housing when mounted.
Angle Mount Dash Clock SOLD
Topic author - Posts: 1720
- First Name: Layden
- Last Name: Butler
