Horn Kit
Model T Matt
First Name: Matt
Last Name: Madison
* REQUIRED* Type and Year of Model Ts owned: 1923
Horn Kit
Post by Model T Matt » Tue Mar 26, 2024 8:10 pm
2 ft Horn kit new in box part T-13802-HS2 asking $80.00 includes shipping call Matt 503-82four-268one
Last Name: Tannehill
Board Member Since: 2002
Re: Horn Kit
Post by JTT3 » Tue Mar 26, 2024 8:31 pm
Thanks Matt
Model T Matt
First Name: Matt
Last Name: Madison
Re: Horn Kit
Post by Model T Matt » Tue Mar 26, 2024 8:32 pm
Held for John
Rick_Rice
First Name: Rick
Last Name: Rice
* REQUIRED* Type and Year of Model Ts owned: 1925 TT Closed Cab Express
Re: Horn Kit
Post by Rick_Rice » Wed Mar 27, 2024 10:39 am
Everyone,
I missed out on this kit and need one real bad for my 1914 open express truck. Please, if anyone else has one available or if you can tell me where I can order a new kit, let me know. Thanks in advance for your reply back!
Kind Regards,
Rick Rice
three three 0 seven one 4 eight one 5 one
Model T Matt
First Name: Matt
Last Name: Madison
Re: Horn Kit
Post by Model T Matt » Wed Mar 27, 2024 10:54 am
will check inv.today bought out a vendor-stock has been out of circuit around 8 yrs-
Rick_Rice
First Name: Rick
Last Name: Rice
Re: Horn Kit
Post by Rick_Rice » Wed Mar 27, 2024 12:02 pm
Matt,
Thanks for your response. I did some on line detective work from your photos and found the kits in Ohio! You are right, the old supplier is no longer around, but by chance I found the old car guy who took over and can help us brass car guys out! I spoke directly with the owner, Jim Watt.
Jim informed me he can supply the kit, which is USA sourced and the kit comes in four (4) different lengths of the flexible brass tube, 2', 3', 4' and 5' lengths. The part number for the kit:
T-13802-HS2
-HS3
-HS4
-HS5
I measured my particular application requirement with a string and found that I need about 40" of flexible brass tube length. Per Jim, the flexible brass tube can be easily shortened, as long as you make a straight clean cut with a cut-off wheel, so I purchased the 4' kit. I hope this helps someone else in their search for a complete brass horn installation kit.
Kind Regards,
Rick Rice
CONTACT:
Vintage Part Club
Jim Watt, Owner
20 West George Street
Arcanum, Ohio 45304
(937)692-6100
Mark Chaffin
Last Name: Chaffin
Re: Horn Kit
Post by Mark Chaffin » Wed Mar 27, 2024 12:14 pm
Vintique makes the horn kit. The word is Chad was waiting on getting the horn bulbs back in stock before making more kits. The horn bulbs are now available.
Rick_Rice
First Name: Rick
Last Name: Rice
Re: Horn Kit
Post by Rick_Rice » Wed Mar 27, 2024 12:40 pm
Good information, thanks Mark! I'm really glad some items are starting to surface and be available again! A guy can order a kit today from Jim (937)692-6100.
