Post
by Scott_Conger » Tue Mar 26, 2024 4:49 pm
Complete LF (other than minor items listed below)
not as good as an OF, but not $400, either
'Way better than an NH
- complete including the float (and the larger version acorn nut which no one makes)
- there's a dent on the inlet which affects nothing, but can be straightened (by you) - can be seen on one picture
- missing adjuster retaining spring - you buy the carb and I'll tell you how to solve that for just a few bucks
- missing one float cover screw which is a common thread and easy to purchase
$90 plus shipping
EMAIL ME
Don't reply here and expect a quick answer or an answer at all
Scott_Conger on Wed Mar 27, 2024 9:26 am, edited 1 time in total.
rickd
- First Name: Rick
- Last Name: Duquette
Post
by rickd » Wed Mar 27, 2024 6:29 am
Scott, sent you an email.
BRENT in 10-uh-C
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Post
by BRENT in 10-uh-C » Wed Mar 27, 2024 8:27 am
Scott, et/al;
Is anyone rebuilding these professionally now?
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Post
by Dan McEachern » Wed Mar 27, 2024 3:52 pm
Brent- Russ Potter stopped rebuilding them when Stan Howe kinda cornered the market on them. Not sure if Jim would be willing to start rebuilding them again. You might give Potters a call and inquire.
Mountainrider
- First Name: Neil
- Last Name: Haywood
- * REQUIRED* Type and Year of Model Ts owned: 1915 roadster
Post
by Mountainrider » Wed Mar 27, 2024 7:43 pm
My LF was in great shape. Just needed a cleaning. Doesn’t start had easy as the G did, but pulls way stronger. I don’t have the Stromberg remote choke set up for it yet. Cory Walker did my G. Maybe he would give the LF a try.
Post
by Allan » Thu Mar 28, 2024 1:35 am
Neil, if it is anything like an OF, any solid wire choke cable will do as long as both ends of the cable housing are anchored. You can always fit the correct one when you find one.
JSteele
- First Name: John P.
- Last Name: Steele
- * REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
Post
by JSteele » Mon Apr 01, 2024 11:56 pm
Lee And Sara Means make OF parts and do a great job of rebuilding them. 417-754-8637
ozarkcreekrats@gmail.com
Post
by Scott_Conger » Tue Apr 02, 2024 9:25 am
Scott_Conger on Sat Apr 13, 2024 11:25 am, edited 2 times in total.
Post
by Scott_Conger » Tue Apr 02, 2024 9:29 am
JSteele
- Last Name: Steele
Post
by JSteele » Tue Apr 02, 2024 10:35 pm
Scott sorry I spaced out your parts production.
