Wanted: '26 Horn Button
RadRacer203
Topic author - Posts: 120
- First Name: Michael
- Last Name: Stroz
Looking for a new horn button for my '26 coupe, I didn't realize how bad the original was until now. My bracket is in good shape, and Lang's stocks the bakelite button itself but I can't buy just the contacts. Here's a picture of what I need:
Re: Wanted: '26 Horn Button
RadRacer203
- Last Name: Stroz
Yeah, I saw that, but I also need the contact plate piece too, I was wondering if anyone on here had a good used one of those and/or the button before I buy the whole new reproduction switch assembly
Sorry I miss read the part needed. What is wrong with the contact that you have? Except for the crack (supperglue maybe) looks like it should work fine unless there is more damage that cant be seen or are the threads stripped?
RadRacer203
- Last Name: Stroz
It appears to be made of rubber? Or something similar? And it's just starting to fall apart. I could make it work, but it wouldn't last longMark Gregush wrote: ↑Sat Apr 27, 2024 2:58 pmSorry I miss read the part needed. What is wrong with the contact that you have? Except for the crack (supperglue maybe) looks like it should work fine unless there is more damage that cant be seen or are the threads stripped?
FATMAN
- First Name: ROBERT
- Last Name: BERGSTADT
I have one on e bay, Bob
eBay item number:196368801798
RadRacer203
- Last Name: Stroz
Got one, thanks!
