Looking for a decent set of roadster L top brackets to hold the top saddles. These differ from the touring brackets in that the horizontal leg is longer, about 5" in length. Please email me thru the website.
Richard
WTB pair of roadster L brackets
RGould1910
Topic author - Posts: 1215
- Last Name: Gould
Philip Lawrence
- First Name: Philip
- Last Name: Lawrence
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Runabout, 1919 Touring
- Board Member Since: 2014
Re: WTB pair of roadster L brackets
Richard, for what year Roadster? Roadster L brackets were shorter than Touring brackets. Not sure why the horizontal leg would be longer. The ones I have seen are the same horizontally as Touring cars.
RGould1910
- Last Name: Gould
The car is a 1912 roadster. Thinking back when I added the top irons to the body, its entirely possible I placed the rear irons in the wrong position. If the only difference between the roadster and touring L brackets is the
vertical length, I may try welding extensions to mine. Without knowing the metalurgy of the brackets, however, welding may not be the answer. I hope I dont have to make a set. Hoping I can find a set that works.
- Last Name: Tannehill
- Board Member Since: 2002
Do you have a picture for reference
