WTB rear axle truss for 26
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Fri May 10, 2024 10:51 pm
I am looking for a truss like the one below for the rear end of my 26 speedster. Let me know what you might have.
Re: WTB rear axle truss for 26
Post by TRDxB2 » Sat May 11, 2024 1:49 am
Repro kit made by Model T Ranch
Todd Touchberry
First Name: Todd
Last Name: Touchberry
* REQUIRED* Type and Year of Model Ts owned: 1919. And 1920
Post by Todd Touchberry » Sat May 11, 2024 9:33 am
What purpose do they serve?
Todd Touchberry
Post by RajoRacer » Sat May 11, 2024 9:59 am
Early riveted housings were prone to flexing (and leaking) - the truss supposedly alleviated the stresses. That photo is of our '14 Touring !
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Sat May 11, 2024 10:36 am
Thanks for the link. My speedster uses lowering plates that cantilever off the rear axle. It will place some new forces on the axle not seen on a standard axle. Providing some extra support is not a bad idea. Plus, I like the look. About the only thing on this car that has not been changed/modified are the block, hogs head, and radiator.
Sarikatime
Last Name: Seress
Post by Sarikatime » Sat May 11, 2024 5:34 pm
It is tricky to put a floor jack under the rear end with the truss in place. It is also difficult to know when you are supporting the axel or possibly over tightening and causing more problems than good. I adjusted mine several times but I was never happy with the functionality of the truss and nobody could tell me how tight or loose it should be. Now it is a decoration only, which I really like the look of, that is why I bought it.
