Wind wing glass wanted
Jim11787
First Name: Jim
Last Name: Sarc
Board Member Since: 2023
Post by Jim11787 » Mon May 13, 2024 8:17 am
Broke one of mine. Measures 18”x7”. Anyone have glass? Figured I check before going to glass shop.
Re: Wind wing glass wanted
Post by Allan » Mon May 13, 2024 7:28 pm
Jim, a matching glass may be difficult. You need to include the radius of the corners to match yours. Is it a rectangle? It may be cheaper to get a matching pair cut by the glass shop and keep your remaining one as a spare. That way you can have laminated glasses.
Jim11787
First Name: Jim
Last Name: Sarc
Post by Jim11787 » Mon May 13, 2024 11:16 pm
Thanks Allan. I figured someone might have a pair of glass they may want to sell. If not, I do have 1 good one a glass shop can template from. The broken one could also be a template as it is laminated. Not sure what a glass shop will charge but probably my only route. I do see them in catalogs for model A’s but they are shorter.
