For sale unknown front hubs.
5 lugs
5 1/4" on center.
$75 for the pair plus shipping in the USA
FS aftermarket front wheel hubs unknown.
Karl Von Neumann
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
Re: FS aftermarket front wheel hubs unknown.
They look like late 20s dodge
Gene_French
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
Karl:
don't think they are Dodge Brothers ... the DB cars had a speedometer drive in the transmission from the earliest cars ... would not use the speedometer drive gear on the 1 hub ...Gene French
Also, Dodge Brothers had swedged in place wheels studs, like the 26-27 wire wheels and Ford Model A's. You might ask here: https://forums.aaca.org/forum/66-what-is-it/
Tim D
Topic author - Posts: 225
- Last Name: Dickson
- * REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
Measured them model T bearing races will fit them.
Maybe the bearing will fit but T wire wheels are 5 on 5, A's are 5 on 5.5.
