Wanted: rear fender mount
Will_Vanderburg
Topic author - Posts: 948
- First Name: William
- Last Name: Vanderburg
I’m looking for a rear fender mount rod that screws into the rear quarter pillar for a Centerdoor Sedan.
You’d think the ones for tourings were the same, but they are not. They are 1/2 inch shorter than CD ones.
I thought I had found one at Luray, but alas, it is too short. (Only paid $5 for it, so no big loss)
The threads on the end are all the same. IF I had an acetylene torch I could straighten the one that I need to have fixed.
Just seeing what’s out there. These are not reproduced.
William L Vanderburg
1922 Center Door Sedan
TFan
- First Name: Jim
- Last Name: Riedy
Re: Wanted: rear fender mount
This what you are in search of? Jim
https://www.mtfca.com/phpBB3/viewtopic.php?f=2&t=43317
Will_Vanderburg
It is similar to that in length only. It doesn’t have the large boss on it. The two that I have are equal length. And are longer than touring ones.
Ken Buhler
- First Name: Ken
- Last Name: Buhler
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster 1927 Coupe
- Board Member Since: 2012
I have a lot of these parts, if you show a photo, I will look at what is there. If anyone needs brackets for wood cars, I may have them. Ken
Work honestly
Stay true to your word
Get the job done right
Will_Vanderburg
This is what I’m looking for. The CD ones that I have are 8 inches in total length (including threaded area)
The one I bought is 1/2 inch shorter.
The diameter is the same on both. I know the threads posted above discussed what these look like. But those were not what was on my body. And the body is ‘22
If the ones with the square boss are 100% correct for ‘22, then so be it. I guess I’ll never find them. (One of the mounts I cannot remove yet. It’s tight).
Pretty darn sure that is a forging not casting so could be done cold.
Will_Vanderburg
I’ve tried that and my vise isn’t man enough. Even though it’s bolted to a table.Mark Gregush wrote: ↑Tue May 28, 2024 4:02 pmPretty darn sure that is a forging not casting so could be done cold.
Will_Vanderburg
Please check your part stashes. Back to top
Will_Vanderburg wrote: ↑Tue May 28, 2024 4:54 pmI’ve tried that and my vise isn’t man enough. Even though it’s bolted to a table.Mark Gregush wrote: ↑Tue May 28, 2024 4:02 pmPretty darn sure that is a forging not casting so could be done cold.
Will_Vanderburg
Ok I’ll break out the BFH!
