Wanted: rear fender mount
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Mon May 27, 2024 3:53 pm
I’m looking for a rear fender mount rod that screws into the rear quarter pillar for a Centerdoor Sedan.
You’d think the ones for tourings were the same, but they are not. They are 1/2 inch shorter than CD ones.
I thought I had found one at Luray, but alas, it is too short. (Only paid $5 for it, so no big loss)
The threads on the end are all the same. IF I had an acetylene torch I could straighten the one that I need to have fixed.
Just seeing what’s out there. These are not reproduced.
William L Vanderburg
1922 Center Door Sedan
TFan
First Name: Jim
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
Re: Wanted: rear fender mount
Post by TFan » Mon May 27, 2024 5:04 pm
This what you are in search of? Jim
https://www.mtfca.com/phpBB3/viewtopic.php?f=2&t=43317
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Mon May 27, 2024 6:27 pm
It is similar to that in length only. It doesn’t have the large boss on it. The two that I have are equal length. And are longer than touring ones.
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Post by Ken Buhler » Tue May 28, 2024 9:39 am
I have a lot of these parts, if you show a photo, I will look at what is there. If anyone needs brackets for wood cars, I may have them. Ken
Work honestly
Stay true to your word
Get the job done right
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Tue May 28, 2024 3:50 pm
This is what I’m looking for. The CD ones that I have are 8 inches in total length (including threaded area)
The one I bought is 1/2 inch shorter.
The diameter is the same on both. I know the threads posted above discussed what these look like. But those were not what was on my body. And the body is ‘22
If the ones with the square boss are 100% correct for ‘22, then so be it. I guess I’ll never find them. (One of the mounts I cannot remove yet. It’s tight).
Post by Mark Gregush » Tue May 28, 2024 4:02 pm
Pretty darn sure that is a forging not casting so could be done cold.
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Tue May 28, 2024 4:54 pm
I’ve tried that and my vise isn’t man enough. Even though it’s bolted to a table.
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Mon Jun 03, 2024 1:13 pm
Please check your part stashes. Back to top
Post by Mark Gregush » Mon Jun 03, 2024 5:32 pm
:) big hammer and anvil!
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Mon Jun 03, 2024 8:08 pm
Ok I’ll break out the BFH!
Post by Mark Gregush » Mon Jun 03, 2024 8:29 pm
:D
