I have to finish my last die that cuts the OD, and I will have an impossible-to-find gasket for U & J carbs available - the precision gasket which joins the throttle body to the main body. This gasket must fit well and be the correct thickness so that the lower shim/gasket over the venturi properly retains and seals the venturi correctly.
No vendor carries them, because no one makes them - that changed this week
If you think "I don't need one now", that's fine, but there won't be much demand for these and I'm only going to make one run. The master die took me 2 weeks of part-time work and a bunch of moo-la for tooling to make, so I will not ever remotely come close to making my money back, but simply enjoy the challenge...and you get to reap the reward of that foolishness.
Note: Billy-Bob's Hotrod Shop isn't going to have this in stock, so don't annoy them by asking
I don't monitor ads since they sink away so fast, so
EMAIL YOUR INTEREST IN PURCHASING THIS GASKET AND I WILL CONTACT YOU WHEN THEY ARE READY
Thank you
U & J carb part - never sold before, ready soon...
Topic author - Posts: 6728
LWBLAKECPA
- First Name: Lawrence
- Last Name: Blake
Re: U & J carb part - never sold before, ready soon...
I’m interested Scott
