WTB one wood coil.
Topic author - Posts: 211
- Last Name: Dickson
- * REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
WTB one wood coil.
WTB one rebuilt wood coil or one that just needs a cap. In Wisconsin. Thanks
- Last Name: Wrenn
Re: WTB one wood coil.
Contact Brent Mize or Ron Patterson
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
Tim I've got a big box of coils here some work some don't pleasant prairie area
thanks have one coming from Adam.
- First Name: Kris
- Last Name: Pawlak
- * REQUIRED* Type and Year of Model Ts owned: 1922
Can you measure the resistance on side prongs?Karl Von Neumann wrote: ↑Tue Jul 02, 2024 12:58 pmTim I've got a big box of coils here some work some don't pleasant prairie area
I bought couple of coils on ebay and they show open circuit, what means bad wires.
I can replace condenser, but not the coil.
- First Name: Karl
I sold all the good coils I had and just got in another small batch but haven't had time to go thru them yetKajtek1 wrote: ↑Sat Sep 14, 2024 7:01 pmCan you measure the resistance on side prongs?Karl Von Neumann wrote: ↑Tue Jul 02, 2024 12:58 pmTim I've got a big box of coils here some work some don't pleasant prairie area
- Last Name: Golden
Another give away for the coil is whether the slide off side has two small nails to hold it in place or a staple.
The ones with the nails have Ford at the top or perhaps if older, in the center of the other side.
I have found coils that make sparks on the Hand Crank Coil Tester with no sparks showing on the StroboSpark Coil Tester.
They always seem to be the ones with the staples and measuring the secondary winding with an ohm meter will show about 2,8000 Ohms or a little less, and they will work in a Model T Coil Box, with a little less hot spark value..
The ones marked Ford all seem to be right at the 3,300 Ohms that appear to be correct and they will always produce the 2,500 Volts that the StroboSpark has to read to light the three bars.
