WTB - Rebuildable 1926-27 Model T engine block s/n 12222529 or higher
joeoldcars
Topic author - Posts: 2
- First Name: Joe
- Last Name: Rush
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1926 Touring
Looking to purchase a rebuildable 1926-27 type Model T engine block to replace one on my engine that cracked through coolant cavity into and top of valve gallery. I have obtained 3 so far, cleaned and crack inspected and found all three with cracks around valve seats heading down to the same area that can’t be used or reliably repaired. Goal is to build this into an engine that will get about 1,200 miles per year (not a trailer queen). Possible exchange location is MTFCI Tour in Cadillac Michigan in July 2024.
Re: WTB - Rebuildable 1926-27 Model T engine block s/n 12990077 or higher
Yeh that's the problem with 26/7 engines...thats their Achilles heel. I have a 26 block but not sure of the number let alone the viability of it. Once it gets done pouring down rain I'll go to the barn & check. It's sitting under another earlier block and blocked by ju k so you know how that goes! Ha ha
colonelpowers
- First Name: Joshua
- Last Name: Powers
- * REQUIRED* Type and Year of Model Ts owned: 1922 Center Door Sedan
I sent you an email.
RandyB
- First Name: Randy
- Last Name: Behrens
- * REQUIRED* Type and Year of Model Ts owned: 1926 Model T Coupe
Re: WTB - Rebuildable 1926-27 Model T engine block s/n 12222529 or higher
I sent a message about a block you may be interested in.
Tim D
- Last Name: Dickson
- * REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
have one in Beloit WI
Along time ago, I had a 26 block with the boss, but not drilled! I have a very late 1925 runabout with a 12,000,000 serial number, and as far as I know they used them during the month of July and early August.
Steve King
- Last Name: King
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring, 25 Coupe, , 26 Touring, 22 Aluminum Fordor, 23 Coupe
- Board Member Since: 2010
I roughed mine up and applied Belzona 1311. I'm running it. All that headache rebuilding, I was determined to make it work. I'm also running water for the summer to allow the interior of the crack to rust.
- Last Name: Tannehill
Steve that stuff is expensive but it’s awesome. Much cheaper than a tear down & rebuild. This stuff is used in the oilfield in high pressure systems & is considered a permanent repair.
JOE DONT WORRY ABOUT THE NUMBER THAT CAN BE FIXED USING YOUR CURRENT NUMBER.
Best John
Best John
joeoldcars
- First Name: Joe
- Last Name: Rush
Still looking for a good 26-27 Ford Model T engine block. Any additional leads are welcome.
Joe Bell
- First Name: Joe
- Last Name: Bell
I have several to look at already tore down give me a jingle Tiffin Ohio
