Turtle Deck MORE PICTURES
Cowtown
Topic author - Posts: 16
- First Name: Jake
- Last Name: Ford Guy
- * REQUIRED* Type and Year of Model Ts owned: 1917
- Last Name: House
Re: Turtle Deck
Now, thats a good deal ! Could be proper for ‘14-early ‘17. Original floor a big plus !
Charlie_26_TT_Ccab
- First Name: Charlie
- Last Name: Coleman
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT C Cab Stakebed Truck
Re: Turtle Deck photos
Good afternoon, I get photos of the floor inside and outside and or top and bottom and the front that butts
against the seat back, thank Charlie
Re: Turtle Deck
It might help someone needing one to know if this one had the front notch out for a battery or not.
- Last Name: House
Re: Turtle Deck
I thought it probably doesn’t because of the cast iron latch handles.
Cowtown
- First Name: Jake
Re: Turtle Deck
I will post more pictures today
Re: Turtle Deck
George House wrote: ↑Sun Jul 14, 2024 6:05 amI thought it probably doesn’t because of the cast iron latch handles.
Hey there George. Apparently, the two styles of handles crossed over for a couple years. Speculation has been different suppliers of turtle decks changed over at different times.
Really hard to know for sure, a lot of runabouts had decks removed and then replaced later, all sorts of things. But While looking for mine for my 1915, I saw several at swap meets and advertisements with the cast or machine turned handles and the kick-out for the battery. I don't recall seeing any turtle decks with the flat handles and no battery access. I won't claim to know the exact proper answer, but I would guess Ford began switching to the later flat handles right around 1919, but probably some cars were still getting the earlier style handle into 1920.
I may be wrong about some of that? I sure would like to read a real time line for this and a lot of other minor changes.
- Last Name: House
Re: Turtle Deck MORE PICTURES
Wayne, you don’t know how much this pains me…..but you’re right….I asked that question to a researcher at the BF Archives and received the following report from Mr. Jim Orr:
According to our (offline) inventory of the Model T part drawings, the Turtle Deck Door Fastener Handle was part T-5644. "Deck Door Handle Fastener - Forging Design" was Part # T-5644-A. "Deck Door Handle Fastener - Pressed Steel Design" was Part # T-5644-B.
The "Record of Changes" cards for T-5644-A and T-5644-B indicate the change was made on September 12, 1921.
If you would like to request images of the drawings, the cost would be $30 each. If you would like to request images of the Record of Changes cards, the cost would be $7 each.
Please let me know if you have any further questions. I hope this helps!
Hey there George H, I can't always be right, but once in awhile I can be?
Thank you very much for the clarification/details.
I always enjoy reading your posts.
