New 09-10 fan blades
Larry Debaugh
Topic author - Posts: 162
- Last Name: Debaugh
- * REQUIRED* Type and Year of Model Ts owned: 1910 Tourabout
Exact 09-10 fan blades die stamped with mounting holes. $140 for a set of 4 , postage $11 US , 09/10 blades have greater pitch than the later blades, Lang’s will rivet the blades on your hub including the rivets for $30. Larry Debaugh 4103361728
Re: New 09-10 fan blades
Excellent job Larry. They are pressed much more deeply and with greater definition than the later ones. In my experience, they may run a little later, up to 1912, but others may know better.
Larry Debaugh
Thanks Allan, yes I think they were used into at least 11, but I have no documentation, I have several different examples of different definition and angle which I assume changed as Ford changed the coolant system capacity. Larry
Dave_Martin
- Last Name: Martin
Larry, Beautiful! Thank you for taking the time to reproduce these correctly.
Larry Debaugh
Thanks, I was desperate… 3 10’s one blade! Lol
Larry Debaugh
9 sets sold , more still available… Larry
Larry Debaugh
12 sets sold …. Others still available
Stephen_heatherly
- First Name: Stephen
- Last Name: Heatherly
Will these work on a later fan?
Stephen
Stephen
Larry Debaugh
Yes will work through the 20’s and move more air because of the increased pitch, I made them for the 9-11 because they were impossible to find… larry
Larry Debaugh
Sets still available
Larry Debaugh
I still have fan blades… Larry
Great job. It's too bad the current blades were not done correctly! They are so close.
