Rajo Over Head T engine For Sale
The lower end was designed and executed by Tom Holthart of Quality Machine, formally Sants Clara, CA. It consists of a Scat counter balanced crank, full pressure oil to the mains, using a VW, cam driven oil pump. Rods are new forged type with inserts. Tom uses a full A size crank and fits "A" inserts into the block. It is a 27 block set up with MCEACHERN 4 dipper dry sump. It has an external oil filter, new push rods, Original Bosch front plate with new Bosch DISTRIBUTOR. The head has stainless valves, rocker shaft setup for pressurized oil.
Over $10K invested, $7500 includes engine stand. Go to:https://www.amuffler.com/forsale.html for photos.
Rajo for sale
- First Name: Edmund
- Last Name: Niedzielski
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
Re: Rajo for sale
The engine looks as pretty as a Bugatti ! A clean and well done job from what I see. Idea- perhaps add a picture showing the rockers and shafts ?
