WANTED Racing style steering wheel
geneabb
Topic author - Posts: 32
- First Name: eugene
- Last Name: abbondelo
- * REQUIRED* Type and Year of Model Ts owned: 1926 touring project
I'm looking for a steering wheel for my 1926 speedster project as used on racing cars at the time. 4 flat spokes with a hub to fit the Model T steering shaft. Wooden rim preferred. I can purchase and pick up at Hershey.
I know it's a long shot but I thought I would try and see if somethings available.
Thanks,
Gene
Union Bridge, Md.
Thanks,
Gene
Union Bridge, Md.
blauvelt
- First Name: Douglas
- Last Name: Ogden
Re: WANTED Racing style steering wheel
Good luck on finding an original!
If that doesn't pan out, Look up a gentleman name, Joshua Shaw, he is on IG under the handle of "jacobs_lader". He works at the Harry A. Miller restoration facility And on the side produces a very nice four spoke race wheel. Imagine that he could help build something that would suit even the most particular of needs.
Good luck
Good luck
babychadwick
- First Name: Chad
- Last Name: Azevedo
Probably something like this?
https://www.ebay.com/itm/156345828337?_ ... R6zunenEZA
It makes a difference what the T is its going into. Often in a speedster the T dish places the wheel too far from the driver.
blauvelt
- Last Name: Ogden
Imagine that if the gentleman wanted one scoop of vanilla and some whip cream on the side, he'd say so. He wants the full sundae, toppings and brandied cherries. Let him dream!
babychadwick wrote: ↑Tue Sep 24, 2024 8:34 pmProbably something like this?
Shannon_in_Texas
- First Name: Shannon
- Last Name: Helm
Gene, these might be a starting point to make your own:
https://straight-eight.com/product/buga ... -armature/
- First Name: craig
- Last Name: leach
Hi Gene,
The fatman adaptor the venders sell moves the wheel up or back
About that much would be a win win. Also Speedway Motors sells a 15” 4 spoke with a 2” dish & 17” 4 spoke 1” dish you will need to make a hub for the Speedway wheels
Kevin Pharis
- Last Name: Pharis
geneabb
Thanks guys for all the links and suggestions. I'm going to see what I can find at Hershey this year. A long shot, I know.
Gene
Gene
Tbz4u
- Last Name: Weitzel
- * REQUIRED* Type and Year of Model Ts owned: 27 coupe,23 touring 14 speedster WILD CHERRY 2 1909 touring 27 roaster
Send me an email I think I have what your looking for robertaweitzel@gmail.com
geneabb
Didn't find the kind of wheel I'm looking for. Lots of stock wheels though.
RecklessKelly
- Last Name: Maxson
I rambled across this one. The seller had two different ones posted.
I have a similar one. Just a caution when looking at any wheel: while the hole diameter may be the proper size; the thickness of the hub may be too thick for bolting onto the steering pinion shaft. Not sure if I did that to the one I have if it would still be too thickRecklessKelly wrote: ↑Sat Oct 26, 2024 1:08 pmI rambled across this one. The seller had two different ones posted.
