WTB - Fender bracket speedster headlight mounts for fenderless speedster
Tom Stephens
Topic author - Posts: 36
- First Name: Tom
- Last Name: Stephens
- * REQUIRED* Type and Year of Model Ts owned: Parts to build a Speedster
WTB - Fender bracket speedster headlight mounts for fender-less speedster
Tom Stephens
Tom Stephens
Kevin Pharis
- Last Name: Pharis
Re: WTB - Fender bracket speedster headlight mounts for fenderless speedster
Most use cut off fender brackets, what mounting style…? Early D shaped mount for gas headlight forks? Black car era V notch?
Tom Stephens
- First Name: Tom
Whoops, thanks for clarification
'25 speedster, so yes, the later style. I've seen the cut-off '26-'27 fender irons
Kevin Pharis
- Last Name: Pharis
I’ll see what I have layin around
Tom Stephens
- First Name: Tom
Great, that will work!!
You might want to match your headlight post's threaded end to the fender iron mount hole for it (no assumptions) .
In addition the 22-25 stop is slight taper
Tom Stephens
- First Name: Tom
Great info!! I am picking up my headlight buckets on October 7th, so will inspect then and report back on the 8th.
Tom
Tom
Tom Stephens
- First Name: Tom
My buckets...
Funny, looks like I have one '15 - '17 and one '22 - '25. How will they both fit the cut-off '26-'27 fender irons?
Layden Butler
- First Name: Layden
- Last Name: Butler
Neither one will fit '26-27 fender brackets. Those later Model Ts have a completely different method of mounting the fender to the frame and the headlights mount to the fenders.
Can you post a picture of the front corner ( either side) of your frame so we can see what you are working with?
You are correct but Tom made an improper reference as having seen "cut-off '26-'27 fender irons". Tom is building a fenderless speedster so 26-27 irons & fenders are out of scope.Layden Butler wrote: ↑Fri Oct 11, 2024 9:33 pmNeither one will fit '26-27 fender brackets. Those later Model Ts have a completely different method of mounting the fender to the frame and the headlights mount to the fenders.
Given what irons he has. Just needs to buy one of each fender iron.. Its a speedster so the mismatch doesn't matter. Or its what a speedster is about, making one from available parts!
It is also possible to make one of headlight posts fit the other style fender iron with a bit of effort
- Attachments
- front fender irons 2.png (239.54 KiB) Viewed 2502 times
Tom Stephens
- First Name: Tom
Layden,
I've attached the photos of the corner of my frame.
PS. I think I bought my steering wheel from you!
Tom
Tom
Some confusion has been caused by the above comment and what your looking for.Tom Stephens wrote: ↑Sun Oct 13, 2024 1:08 amLayden,
Tom
by Tom Stephens » Tue Oct 01, 2024 7:29 pm
The holes shown in your frame picture (and headlights) indicate you need an "iron"
the 1926-27 Fenders used a "bracket" (4858) not an "iron" (4808-M or 4809)
Tom Stephens
- First Name: Tom
Mine is a speedster without fenders, so as far as I know, I need something like 4809 so I can mount headlights thru the holes in 4809, thus not needing and cutting off the rest of the fender iron.
As far as the year "iron" I need, I do not know.
This what is typically used for the headlights you have. They are fender irons with the rods cut off. --Tom Stephens wrote: ↑Sun Oct 13, 2024 1:24 pmMine is a speedster without fenders, so as far as I know, I need something like 4809 so I can mount headlights thru the holes in 4809, thus not needing and cutting off the rest of the fender iron.
Since the posts of the headlights you have are different you can get one of each or just one style 4804-M and file the sides of the tapered one. Don't worry about the taper. Try Bob's Antique Auto Parts he has a ton of the Front Fender Irons - he's the FATMAN on the forum
Tom Stephens
- First Name: Tom
I rec'd my fender irons, each one matching the flat and tapered stems, I couldn't be more pleased. Thanks for all the helpful info!
Tom
Tom
