WTB - Fender bracket speedster headlight mounts for fenderless speedster
Tom Stephens
Last Name: Stephens
* REQUIRED* Type and Year of Model Ts owned: Parts to build a Speedster
Post by Tom Stephens » Tue Oct 01, 2024 5:34 pm
WTB - Fender bracket speedster headlight mounts for fender-less speedster
Tom Stephens
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: WTB - Fender bracket speedster headlight mounts for fenderless speedster
Post by Kevin Pharis » Tue Oct 01, 2024 6:28 pm
Most use cut off fender brackets, what mounting style…? Early D shaped mount for gas headlight forks? Black car era V notch?
Tom Stephens
Last Name: Stephens
Post by Tom Stephens » Tue Oct 01, 2024 8:29 pm
Whoops, thanks for clarification :-)
'25 speedster, so yes, the later style. I've seen the cut-off '26-'27 fender irons
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Oct 01, 2024 9:23 pm
I’ll see what I have layin around
Tom Stephens
Last Name: Stephens
Post by Tom Stephens » Tue Oct 01, 2024 11:49 pm
Great, that will work!!
Post by TRDxB2 » Wed Oct 02, 2024 11:29 am
You might want to match your headlight post's threaded end to the fender iron mount hole for it (no assumptions) .
In addition the 22-25 stop is slight taper
22-25 taper.png (44.49 KiB) Viewed 2800 times
Tom Stephens
Last Name: Stephens
Post by Tom Stephens » Wed Oct 02, 2024 10:20 pm
Great info!! I am picking up my headlight buckets on October 7th, so will inspect then and report back on the 8th.
Tom
Tom Stephens
Last Name: Stephens
Post by Tom Stephens » Fri Oct 11, 2024 9:10 pm
My buckets...
Funny, looks like I have one '15 - '17 and one '22 - '25. How will they both fit the cut-off '26-'27 fender irons?
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Fri Oct 11, 2024 9:33 pm
Neither one will fit '26-27 fender brackets. Those later Model Ts have a completely different method of mounting the fender to the frame and the headlights mount to the fenders.
Can you post a picture of the front corner ( either side) of your frame so we can see what you are working with?
Post by TRDxB2 » Fri Oct 11, 2024 11:35 pm
You are correct but Tom made an improper reference as having seen "cut-off '26-'27 fender irons". Tom is building a fenderless speedster so 26-27 irons & fenders are out of scope.
Given what irons he has. Just needs to buy one of each fender iron.. Its a speedster so the mismatch doesn't matter. Or its what a speedster is about, making one from available parts!
It is also possible to make one of headlight posts fit the other style fender iron with a bit of effort
front fender irons 2.png (239.54 KiB) Viewed 2507 times
Tom Stephens
Last Name: Stephens
Post by Tom Stephens » Sun Oct 13, 2024 1:08 am
Layden,
I've attached the photos of the corner of my frame.
PS. I think I bought my steering wheel from you!
Tom
Post by TRDxB2 » Sun Oct 13, 2024 11:20 am
Layden,
Tom
Some confusion has been caused by the above comment and what your looking for.
by Tom Stephens » Tue Oct 01, 2024 7:29 pm
The holes shown in your frame picture (and headlights) indicate you need an "iron"
the 1926-27 Fenders used a "bracket" (4858) not an "iron" (4808-M or 4809)
Tom Stephens
Last Name: Stephens
Post by Tom Stephens » Sun Oct 13, 2024 1:24 pm
Mine is a speedster without fenders, so as far as I know, I need something like 4809 so I can mount headlights thru the holes in 4809, thus not needing and cutting off the rest of the fender iron.
As far as the year "iron" I need, I do not know.
Post by TRDxB2 » Sun Oct 13, 2024 2:30 pm
This what is typically used for the headlights you have. They are fender irons with the rods cut off.
Since the posts of the headlights you have are different you can get one of each or just one style 4804-M and file the sides of the tapered one. Don't worry about the taper.
fix it.png (396.64 KiB) Viewed 2272 times
Try Bob's Antique Auto Parts he has a ton of the Front Fender Irons - he's the FATMAN on the forum
Tom Stephens
Last Name: Stephens
Post by Tom Stephens » Mon Oct 28, 2024 1:29 am
I rec'd my fender irons, each one matching the flat and tapered stems, I couldn't be more pleased. Thanks for all the helpful info!
Tom
