Looking for a pair of Rocky Mountain brake bands for a 26 (buy or trade for earlier bands)
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Mon Oct 14, 2024 8:52 pm
I have a new complete set of Rocky Mountain brakes for a small drum car, but I need a set for my 26 speedster. I checked with Chaffin’s, who normally carry the bands separately, and they are not available at the moment. I was planning to keep the parts for the small drum as spares for my 22 that has Rocky Mountains on already.
So, does anyone have a set of good Rocky Mountain 26-27 bands they would be willing to sell? I don’t need any of the other parts, just the bands. I would also be willing to swap my bands if someone has 26-27 bands and needs the earlier ones.
A sample of the bands I have on hand
Last edited by Reno Speedster on Tue Oct 15, 2024 12:31 am, edited 1 time in total.
Re: Looking for a pair of Rocky Mountain brake bands for a 26 (buy or trade for earlier bands)
Post by speedytinc » Mon Oct 14, 2024 9:02 pm
I dont think the mounting brackets are the same since the drums are not the same diameter. Further research is warranted.
Ed Fuller
First Name: Ed
Last Name: Fuller
Board Member Since: 2012
Post by Ed Fuller » Mon Oct 14, 2024 9:19 pm
John is correct. The small drum and large drum mounting brackets are different and will not interchange.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Mon Oct 14, 2024 10:06 pm
Sorry I did not make it clear. I am using custom brackets that support the Rocky Mountain brakes and drop the axle. So different brackets are not an issue for me. I just need the right bands.
First Name: craig
Last Name: leach
Post by Craig Leach » Tue Oct 15, 2024 1:13 pm
This comes up every once in a while. Has anyone considered having a piece of flat rolled into a ring & welded just a little smaller than the
26-27 drum, heat & press over the 26-27 drum, weld it on & have it turned or ground to the correct size for the larger drum? That would make
it a much more robust drum also.
NPorter56
First Name: Neil
Last Name: Porter
* REQUIRED* Type and Year of Model Ts owned: 1925 TT Truck
Post by NPorter56 » Tue Oct 15, 2024 1:58 pm
Hi - Don't know if these will work for you. I they are for TT Truck but fit on 26-27 drum. Band is a little too wide but don't think that matters.
I have three of these I was going to list for sale. Neil
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Wed Oct 16, 2024 1:35 am
If push comes to shove, I could make bands. But, I understand the parts will be available once things get back to normal for the folks who make Rocky Mountain.
I am not sure those bands are for Rocky
Mountains. They have a bracket I don’t see on the ones I have.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Wed Oct 16, 2024 2:58 am
The bands that Neil posted pictures of are late '20s Chevrolet and will work just fine on 26-27 drums. If you are making brackets, just design them to work with the Chevy bands. Or- call Bud Williams an buy just buy the RM bands from him.
Tinner12
First Name: Vernon
Last Name: Enis
* REQUIRED* Type and Year of Model Ts owned: 1917 and 1924 touring,1926 4 door
Board Member Since: 2011
Post by Tinner12 » Thu Oct 17, 2024 3:40 pm
are these what you need
Tinner12
First Name: Vernon
Last Name: Enis
Post by Tinner12 » Thu Oct 17, 2024 4:05 pm
these say pat 4-6 -23 on them and RH and LH Cleveland
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Fri Oct 18, 2024 10:23 pm
Very cool, but not what I am after.
