this adapts the FORD 1/4" fuel line to the S4BF 5/16" inlet - just found this in stock
I will be making more this summer, but this one is available immediately
High quality, silver soldered connection - no lead solder; no junk
EMAIL FOR INFO
Example of adapter installed - you are not purchasing a carburetor with this part
FS - Zenith S4BF fuel line adapter
Topic author - Posts: 6800
Re: FS - Zenith S4BF fuel line adapter
I thought I remembered someone out there asking about one and when I was going to make more (?)
If this doesn't go fairly soon, there sure won't be any more for a long time...no point investing time and materials into things that no one wants or needs.
Full Flow Float Valves keep me busy enough!
tom leroux
- First Name: TOM
- Last Name: LEROUX
- * REQUIRED* Type and Year of Model Ts owned: 1915 speedster-1927 pick up
Scott
will take two when you make them
thanks tom leroux
thanks tom leroux
tom leroux
- First Name: TOM
- Last Name: LEROUX
scott
I will take the one you have
tom leroux
tom leroux
