Hudco Ford Slip Out Pedal Transmission Cover
Topic author - Posts: 281
- First Name: Don
- Last Name: Lang
- * REQUIRED* Type and Year of Model Ts owned: Multiple years
Sale Pending to Scott M. Interesting accessory Hudco Transmission Cover. Possibly New Old Stock because of never having pedals, pedal cams, and clutch shaft installed. This cover allows you to remove all the pedals to change the bands easily. It has been glass beaded, NOT sandblasted. $250 plus shipping or delivered free to Hershey this fall. Call Lang’s at 1-800-872-7871
- First Name: Chris
- Last Name: Landry
- * REQUIRED* Type and Year of Model Ts owned: 1915 Speedster, 1926 Touring, 1923 Depot Hack project
Re: Hudco Ford Slip Out Pedal Transmission Cover
I saw one of these at Hershey. (maybe this one? Not in the Lang's booth) Very interesting accessory. We couldn't figure out what the large pipe plug on the top is for. Any ideas?
- First Name: Jack
- Last Name: Putnam
Pipe plug is for inspection of the oil tube.
- Last Name: Hatch
My 25 Canadian RHD Roadster Pickup has a pipe plug like. I think it was a neat addition.
- First Name: Rick
- Last Name: Epstein
Kinda cool. Only leaks while running or stopped
- First Name: Ed
- Last Name: Martin
I had one installed many years ago on a speedster, I used the felt transmission seal with some silicone to fasten removable section, it didn’t leak at all. Made changing the bands an easy chore. Neat accessory.
I also have one waiting to install next time I pull the engine from the '19 Centerdoor - ever had to replaced bands in a Centerdoor ????
- Last Name: Maxson
Looks like longer pedal shaft bosses which would resist wear.
- First Name: Bob
- Last Name: Kiefaber
- * REQUIRED* Type and Year of Model Ts owned: 1906 model F, 1907 model R, 1915 centerdoor sedan, 1921 centerdoor sedan
