FS Front Wood Wheel Hubs
Topic author - Posts: 6340
I recently purchased a barn load of T parts. In the process of sorting it all out so what I have is not limited to the following:
I have a number of front wood wheel hubs.No time to clean them up (de-grease) or check the bearings out and if I did the price would be higher. Doubt if the bearings are any good. I am checking hub cap threads & keyways etc. $35 a hub w flange ( plus shipping )
Also have a number of spindles with spindle arms attached. I have checked these out: all good threads, keyways & good for a tight inner race. Have both round collar & flat collar left & rights (no 1926/27) $30 each plus shipping.
Local pickup is available as well
Re: FS Front Wood Wheel Hubs with Tapered Bearings +
still available
2 sets pending
- First Name: Raymond
- Last Name: Emling
- * REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo, 1914 roadster, building:1910 roadster, 1911 touring
I am looking for thin ring hubs without the speedo ring cut.i am looking for Two sets with old bearing.can you help.
Can you send pictures of the pairs. Thanks Ray
Don't have any
- Last Name: Emling
Do you have two match sets?
- Last Name: Emling
I will take Two sets, Please send pictures. Thin ring only,please.thanks Ray
What are you referring to as a "thin ring" Ray ?
- First Name: Marty
- Last Name: Ray
- * REQUIRED* Type and Year of Model Ts owned: 1916 Runabout, 1922 Roadster
I will take two sets, PM to follow.
- Last Name: Emling
Have not heard from you on the two sets.
Thanks Ray
Thanks Ray
Getting confused with two people each asking for 2 sets. Sent you a PM at 12.30pm Now I see you want two hubs, yes I have them will email you
Getting confused with two people having RAY in their names & each asking for 2 sets. Sent you a PM yes I have them will email you
- Last Name: Emling
Great, thanks
bump da bump
