FS Pinions 11 tooth One Ford script with some small pits (copper colored) & one non script $ 50 each + the ride
Craig.
FS 11 tooth pinions ( non script sold)
Topic author - Posts: 1970
- First Name: craig
- Last Name: leach
- Last Name: van Ekeren
Re: FS 11 tooth pinions
It could be possible that the one with the dot is a later one and needs to match a ring gear with a dot as well.
- First Name: craig
- Last Name: leach
Hi Frank,
To the best of my knowledge that is that dot is a hardness test mark I certainly hope its not as I have never seen a ring gear with a dot?
Every ford script pinion I have seen I believe has that dot. It is also on the other end of the gear.
Craig.
Craig.
- First Name: craig
- Last Name: leach
Re: FS 11 tooth pinions ( non script sold )
To the top. All of the pits in the Ford script pinion are in the pics. They do not appear to be rust or flaking. looks to have been run long after
they where made.
they where made.
- First Name: Ken
- Last Name: Buhler
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster 1927 Coupe
- Board Member Since: 2012
Hello Craig, we haven't spoken for quite a while. I'm looking forward to an update. I would like to buy the one on the left.
Ken
Ken
Work honestly
Stay true to your word
Get the job done right
- First Name: craig
- Last Name: leach
Re: FS 11 tooth pinions ( non script sold)
Non script pinion sold Thanks Ken.
Craig.
Craig.
