Ford shop coat
Grntea
Topic author - Posts: 238
- Last Name: Tagert
- * REQUIRED* Type and Year of Model Ts owned: 1926, 1925, 1923, 1921, 1918
Ford shop coat
I am very interested in getting a Ford shop coat like the one pictured below. If you have one and are not using it - I would appreciate a chance to put it to good use!
- Attachments
- IMG_3741.jpeg (28.91 KiB) Viewed 2251 times
Grntea
- Last Name: Tagert
Re: Ford shop coat
Back to the top please! Thank you MTFCA
- Last Name: Hjortnaes
Re: Ford shop coat
sent you an IM
Grntea
- Last Name: Tagert
Re: Ford shop coat
tom_strickling
- First Name: Tom
- Last Name: Strickling
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Re: Ford shop coat
Check out the Early Ford v-8 museum in Auburn Indiana. The have a White shop coat in their gift shop
https://early-ford-v-8-foundation.squar ... se&q=false
CDooREDW
- First Name: Ron
- Last Name: Wenzel
- * REQUIRED* Type and Year of Model Ts owned: ‘14 SWT Runabout; ‘22 Center Door
Re: Ford shop coat
All,
I called the Piquette Plant and they gave me the link for the holiday specials where can be found the Piquette shop coat and coveralls.
https://www.jotform.com/form/242654985288171
Regards,
Ron in HSV
Regards,
Ron in HSV
Re: Ford shop coat
Early Ford V-8 museum only has Medium in stock. If it is like the brown one above, I am 5'8", 160 pounds and can just fit it. Not tight, but not loose either. Just an FYI.
Wish they had a pic of the front to see if it has the buttons with a flap to prevent scratching.
I tried getting white coveralls made by Red Kap thru Amazon. They must all be modeled by someone 5'6" tall and a Eunuch. I tried different models and sent them all back because they were tight over the shoulders. I think I have to go to Indy and try on what they have before I will find one that fits.
TeveS-Nor Cal
- Last Name: Straw
- * REQUIRED* Type and Year of Model Ts owned: 1915 and lots of parts
Re: Ford shop coat
I have 2 for sale. 1 medium and 1 large. Both worn about two times- like new condition.
