bolt remover on generator SOLD
Topic author - Posts: 1705
- First Name: Melba
- Last Name: Nolan
- * REQUIRED* Type and Year of Model Ts owned: 23 roadster
For sale: Holds generator to remove bolt on side. $50 plus postage
Re: bolt remover on generator
email sent
- Last Name: Golden
Would anyone know what company made that bolt remover?
That will take up a lot less space than the one I am using.
- First Name: Austin
- Last Name: Farmer
Sure would be nice if they made a reproduction of those!
- Last Name: Hatch
Jim I think that one is home made.
- Last Name: Stevenson
An impact gun and 1/2" impact driver works for the vast majority of them. I removed and installed 100's of them that way. If it gets stuck, then you have to drill the bolt out in a drill press.
Pro tip: use an exhaust tube spreader to hold the field poles in place and really seat them on both starters and generators.
Assistant WebSite Admin
www.modeltregulators.com
www.modeltstarters.com
- Last Name: Golden
Dan:
You are right again, as usual.
They are both homemade, my red one cost me $100 and worked great.
