Original Brass Schrader tire valve covers / dust caps
KiwiFordGuy
Topic author - Posts: 72
- First Name: Alex
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1925
A very nice set of original Schrader brass era valve covers as pictured. $220 USD including freight.
PayPal friends and family.
Please private message if interested
KiwiFordGuy
- First Name: Alex
- Last Name: Brown
Tbird
- First Name: Mike
- Last Name: Bird
Re: Original Brass Schrader tire valve covers / dust caps
I believe those rim nuts fit the 725 valve stems.
Bill Everett
- First Name: Bill
- Last Name: Everett
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1914 Touring, 1912 Roadster PickUp in process
- Board Member Since: 2011
Mike, in your opinion, do you feel that the rim nuts pictured are not a match for the valver covers shown?
BigAl
- First Name: Alan
- Last Name: Stein
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring (August 1911)
My basket case late 1911 Touring did have a couple of these rim nut/washers on a couple of wheels. I understand between 1911 and when I purchased the car in 1980 a lot of things could have been changed. But my research has lead me to believe these are correct. The rim nuts just need a leather washer on the rim side. These original rim nuts/washers with the markings are very hard to find. Once again only my opinion.
Tbird
- First Name: Mike
- Last Name: Bird
Hi Bill, so those valve covers will fit with those rim nuts, however those rim nuts fit the 725 valve stem size and so you will have to do a lot of turning the cover to get it off the stem. The original round rim nuts had a small shoulder that the covers threaded onto. The rim nut have pictured below fit the smaller diameter 777 stems. They also do not have any markings on them.Bill Everett wrote: ↑Fri Nov 08, 2024 10:06 amMike, in your opinion, do you feel that the rim nuts pictured are not a match for the valver covers shown?
KiwiFordGuy
- First Name: Alex
- Last Name: Brown
KiwiFordGuy
- First Name: Alex
- Last Name: Brown
To anyone interested, send me a sensible offer via private message.
