FS high rad shell $100
fordrelic
Topic author - Posts: 519
- First Name: Clay
- Last Name: Atkins
- * REQUIRED* Type and Year of Model Ts owned: 1921 Roadster
For Sale high radiator shell.
This is a brass/nickel shell that will need cleaning.
The issue is on inside one vertical edge is is cracked, see picture.
I thought maybe someone could silver solder?
$125 plus shipping.
$125 plus shipping.
BarnesvilleT
- First Name: William
- Last Name: Hallada
- * REQUIRED* Type and Year of Model Ts owned: 1926 Model T Coupe
Re: FS high rad shell
Do you have the bottom flange on the left side?
fordrelic
- First Name: Clay
- Last Name: Atkins
its there, but it's hard to see in pictures. I can take closeup if you are interested.
BarnesvilleT
Thanks for posting the photos. I am not sure I have the ability to fix that long split.
I think I will look for others but will contact you if I am not successful to see if it is still
available.
Thanks,
Bill H.
available.
Thanks,
Bill H.
Bill, rather than a split, it is most likely a wear groove due to a poorly fitted hood. These are quite common on brass shells. It can most satisfactorily be fixed by folding a brass strip to lay along the inside of the shell and silver soldering it in place through the wear groove. This will require some skill by the solderer. If the rest of the shell is not beaten up, it is a worthwhile repair job.
fordrelic
- First Name: Clay
- Last Name: Atkins
Re: FS high rad shell $100
$100 plus shipping
fordrelic
- First Name: Clay
- Last Name: Atkins
$100 plus shipping
fordrelic
- First Name: Clay
- Last Name: Atkins
$100 plus shipping approx. $30
fordrelic
- First Name: Clay
- Last Name: Atkins
to the top
