Two-piece driveshaft fs. Richmond reminder. Sold sold
Topic author - Posts: 1408
- First Name: Mike
- Last Name: Leonard
- * REQUIRED* Type and Year of Model Ts owned: 6
Actually the whole rear end. Two-piece driveshaft, forged end radius rods, 13 -14 rear end,, Chicago duplex cantilever spring assiste. Richmond is coming, I'm in mt.vernon Indiana. Come load your truck. 800.00 for driveshaft alone. If you take it all( minus wheels) the price is 1250.00. ctleonard64@gmail.com
- First Name: Mike
Re: Two-piece driveshaft fs. Richmond reminder
Come down to mt.vernon Indiana and visit. Have alot of A parts and flathead v8 engines
- First Name: Mike
Still for sale
- First Name: Ervin
- Last Name: Mims
- * REQUIRED* Type and Year of Model Ts owned: 12 rdstr 13 tor 14 tor 15 pickup 22 drs coupe 21 center door
Has the rear end? Been rebuilt or 1200 the price for a non-rebuilt rear end. Move to top
- Last Name: Tannehill
2 piece drive shaft complete, closed pinion housing, early radius rods & aftermarket accessory rear springs on top of factory taper leaf springs. It appears that there are Hyatt bearings, axles & so forth if you buy the full meal deal. Could be but I doubt it that the rear axle is rebuilt for that price.
- First Name: Mike
The rear end has not been rebuilt, but it did come out of a running driving car.
- First Name: Brian
- Last Name: Harlamoff
- * REQUIRED* Type and Year of Model Ts owned: 1913 Runabout, 1922 speedster
Can you post a closeup photo of the spool at the front of the rear end? (between the torque tube and the rear end)
- First Name: Mike
Couple of pictures
- Last Name: Hatch
2PC driveshaft tubes use to bring almost what the price is for whole unit.
- Last Name: Gould
Not around here. At least not in the past 20 yesrs. Top going rate for a 2 pc ds was $800. Now a bit less. Example: the cost of a very nice 1913 rear end complete with 2 pc ds and forged radius rods $800 two years ago.
The one advertised looks good and has the early no hump spool. Id be interested to see if the ujoint ball ring has the raised boss for the grease cup.
- First Name: Mike
Pictures of the ball ring
- Last Name: Gould
Looking closer, it appears the spool is a transition between the two styles we usually see,
consistent with the 13 axle housings. The ring may be the later version. 2 piece driveshafts are hard to find when you need them.
- First Name: Mike
Another round
- First Name: Mike
Still have the girl, and a front end to match
- First Name: Mike
Getting harder to find these
- First Name: Mike
This has been around awhile, throwing it back out there. Spring is coming! ctleonard64@gmail.com
- First Name: Mike
Spring is finally coming! Someone surely has a need for these, along with a front end to boot. Email me at ctleonard64@gmail.com
I think the first photo after the phone screenshots does show the humps around the bearing spool at the back, so it suits the rest of the parts.
- First Name: Mike
She is still in the barn. Came out of a running, driving car. ctleonard64@gmail.com
- Last Name: Hatch
Someone was looking for the springs while back. I posted a link to this, but guess he didn’t want them bad enough.
- First Name: Mike
One of these days I'll post this and someone will be thrilled to the gods to have finally found one! Is today the day? ctleonard64@gmail.com
- Last Name: Gould
Agreed. When you need once, they're impossible to find. After you find one, the market becomes flooded. Same with no "made in usa" heads, cast end radius rods etc.
- First Name: Mike
I know people are tired of seeing this old post. Someone needs this! In mt.vernon Indiana. Have a front end also. ctleonard64@gmail.com
- First Name: Mike
- Last Name: Ghormley
OK, I can't stand thinking about this anymore... I'll take it!
Thanks, MikeG
- First Name: Mike
Met Mike and his wife last week , good folks. Seeing the rear end got the best of him , he called when he got home . The rear end finally sold. Thank you mtfca and you mike
