WTB outer races NEW
Tim D
Topic author - Posts: 221
- Last Name: Dickson
- * REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
WTB outer races NEW
looking for 2 new Timken outer front races.
Re: WTB outer races NEW
Can't beat their prices
https://www.rockauto.com/en/catalog/for ... aring,1672 --
https://www.rockauto.com/en/catalog/for ... +plug,7212
- Last Name: Hjortnaes
Never hurts to buy spare races and bearings from RockAuto. Just keep them in the box on the shelf. When you need one, they will be out of stock and no one else will have it in stock.
I'll second that. And once RockAuto is out-of-stock the new price will be higher than before
- First Name: Austin
- Last Name: Farmer
I dont want to take over a thread that isnt mine, but are the rock auto outer bearings threaded? If they are the picture isn't right.
Austin
Yes. They are threaded.
Use this chart. I think I got it from Steve.
What picture are you referring to? The numbers are the same as in the chart.1925 Touring wrote: ↑Sun Dec 29, 2024 1:50 pmI dont want to take over a thread that isnt mine, but are the rock auto outer bearings threaded? If they are the picture isn't right.
- Last Name: Farmer
Thanks all. It makes sense to me now.
A full order, minus seals, comes out to be a little over $200 plus shipping, tax, and the other 8 yards.
An outer race like the O.P. wants is $7.74 each.
Tim D
Thank you . Never thought about RockAuto for this. Buy other things from them.
Austin
Yes, Rockauto used the wrong photo for the bearings. Just go by the numbers. You will get the right item.
Just a heads up. I think you'll find that many Major supplier use "representative" images of a product to convey the a general view of the product. In the case of the RockAuto photos when the are zoomed in show a general roller bearing likely used for all roller bearings they sell. If you scrolled across the the arrows there are 4 images. So don't always expect the image to be the desired product, which means further checking is needed
Interestingly enough the TIMKEN site makes no mention of "threaded"for the bearing
https://cad.timken.com/item/tapered-rol ... rial/09075
