Looking for Delco Distributor twin spark, parts or whole, caps and rotor.
John
WTB Delco Distributor twin spark
Tom VanMeeteren
- First Name: Tom
- Last Name: VanMeeteren
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 1923 touring
Re: WTB Delco Distributor twin spark
Contact me via PM for cap, rotor and points
Tom
Tom
Your inquiry is to vague. It would help your cause/quest to answer some of the questions asked of you in your Nov 4 post. Especially of Kevin Pharis.
I don't know what you are after. Is it a Stutz style with 2 4 cyl caps built to replace a normal magneto? If so, there are 2 different type cap mounts.
The body's were built in 2 styles, one backwards to the other. We/I would need to know the type of drive. A Bosch type to replace the generator or a Matco front cross drive style.
If you are looking for an 8 plug cap with 2 coil inputs as Kevin showed, I couldn't help you with that style.
