3 & 4 Dip Cast Aluminum Oil Sumps- Any Interest?
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Wed Dec 18, 2024 12:56 am
I have had several recent inquiries regarding my 3 and 4 Dip cast aluminum oil sumps. I have stocked these in the past but demand has dropped off over the years as costs have continued to increase. I can do a run of these if there is sufficient interest. The casting is designed to work with either a 3 or 4 dip pan. When used on a 4 dip pan, the rear rod dip is exposed as shown in the 2nd picture below. If you are interested please post a reply here , PM me with a message or send me an e-mail at dmcgearsATyahooDOTcom. Estimated cost will be in the $275- $300 range plus shipping, as I'm getting a current quote from the foundry. As always, they would be cast in 356 T-6 aluminum. I will need firm commitment for a minimum of 5 sumps in order to do this. Lead time from the foundry is around 6 weeks. Thanks, Dan
Dan McEachern
First Name: DAN
Re: 3 & 4 Dip Cast Aluminum Oil Sumps- Any Interest?
Post by Dan McEachern » Thu Dec 19, 2024 1:17 pm
We just received a current quote from the foundry. The price will be $250 each plus shipping plus sales tax if shipping to Ca.
If you have any interest or an up coming project, now is the time to order. Quoted lead time was 8 weeks. Thanks, Dan
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1915 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Post by BRENT in 10-uh-C » Fri Dec 20, 2024 4:10 pm
Dan, I am unsure of the shrinkage rate between aluminum vs. brass/bronze, but can your foundry cast one of the deep sumps in bronze if you had an order already doing other alloy ones??
Dan McEachern
First Name: DAN
Post by Dan McEachern » Fri Dec 20, 2024 6:06 pm
I can certainly check for you, but that is going to be one very heavy casting. I would imagine the metal cost alone would be north of $150.00
stay tuned............
Dan McEachern
First Name: DAN
Post by Dan McEachern » Mon Jan 13, 2025 12:19 am
TTT one more time
Jamie Maxwell
First Name: Jamie
Last Name: Maxwell
* REQUIRED* Type and Year of Model Ts owned: 1919 touring
Post by Jamie Maxwell » Tue Jan 14, 2025 9:09 am
Changing from the original question, did you make exhaust header components at one time for a stock head model T speedster ? Thank you
JH1427
First Name: Jerome
Last Name: Hoffman
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 Roadster, 1923 Speedster, 1923 Racer, 1921 TT Wood Cab
Post by JH1427 » Thu Jan 30, 2025 1:13 am
At school,(art dept.) bronze is now about 6 bucks a pound. Depending on how thick the casting is this could easily be 10-12 pounds.
model_t@swbell.net
Projects: 1916 Speedster - Dec 15', 1921 TT Wood Cab and Bed, 1923 Racer ( My dad's), 1923 Speedster (started in HS)
1924 Roadster - Dec 23' (eBay) and 1924 Touring - June 24' ( Dad's Car been in the family since 1948)
